PXI
The input and output resistances in Remote sense (4-wire)
Hello everyone !
I have searched the information about  input and output resistances in 4-wire mode. Not of results.
Where I can read about this concerning PXI-4140, 4132 ?
Message 1 of 8
(4,122 Views)
Have you installed NI DC Power in LabVIEW? The help documentation has more information to supplement the manuals and spec sheets we have listed online.
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/ssnav:drv/fil/phwebntpmdm:123596/
Chase
NI Technical Support Engineer
Message 2 of 8
(4,096 Views)
Yes, I have seen this documentation. It named the NI DC Power Supplies and SMUs Help, but I did not find the information about the value of input (output) resistance
Message 3 of 8
(4,085 Views)
I do not see this specified anywhere so far.
Can you give more information about why you need that information so that we can determine if there are other resources available?
Chase
Message 4 of 8
(4,079 Views)
For example, I needed to measure with help PXI-4140 the small change of the voltage , and it value will be depends from outer resistance
Message 5 of 8
(4,073 Views)
I found this documentation on 4 wire measurements
http://zone.ni.com/reference/en-XX/help/370384N-01/dmm/4-wire/
What is the resistance range we are operating in?
Chase
Message 6 of 8
(4,060 Views)
I do not need measure the resistance . I want to measure the small voltage with help SMU.
Message 7 of 8
(4,033 Views)
Can you expand upon what you mean by the outer resistance, and what you are measuring?
Chase
Message 8 of 8
(4,022 Views)
