PXI
The PXIe-1084 chassis is not detected by NI MAX but devices on it are
According to the documentation of the PXIe-1084 chassis, he should appear in the drop-down list "Device and Interfaces".
But it's not the case on mine ! It display devices plugged on it, though.
I want to be sure that is a normal/expected behavior.
Benjamin R
Message 1 of 17
(4,864 Views)
Hello
This is actually not normal. What chassis are you using?
Also want to figure it out, how did you connected PCI card to your PXIe chassis?
Is this a screenshot from your PXIe controller's OS?
Message 2 of 17
(4,838 Views)
Maybe with this schema it will be more clear ?
Message 3 of 17
(4,832 Views)
Hello
Why did you don't want to connect the monitor, keyboard and mouse direct to PXI controller to avoid such type of  issues?
Message 4 of 17
(4,758 Views)
Hello Hamlet23
I don't understand your remark...
But thanks for trying!
Message 5 of 17
(4,750 Views)
Can you provide a MAX Tech Report? This will let us know what SW is installed and whether the appropriate services are running.
Additionally, I see you're using Fiber cables. I believe you have done this already, but can you confirm that you've set dip switch 3 on the PCIe-8381 to ON per this manual
Lastly, can you run through are MXI troubleshooting guide? It gives a good number of steps to try when facing MXI enumeration issues.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0MKCAY&l=en-US
Message 6 of 17
(4,734 Views)
It looks like you're missing the driver for the PXIe-8381, which is included with PXI Platform Services (sorry, I don't have a link for the installer). Installing that should fix the problem.
- Robert
Message 7 of 17
(4,730 Views)
Hello Robert,
Before you send me this message, I did a update of NI - max and PXIe-8381 "appear".
But my concern is about the PXIe-1084 chassis.
I just installed this "PXI Platform Services 20.5". But it doesn't fix my problem.
Thanks anyways!
Benjamin R
Message 8 of 17
(4,702 Views)
Hello Captain_K,
Yes, of course !
About the "dip switch 3" I did not installed the device myself but again the PCIe-8381 doesn't seems to be the issue, here. (By the way, the PXIe- 6345 card works perfectly fine)
But I appreciate and keep in mind the remark.
MXI troubleshooting is still relevant for the PXIe-1084 chassis ?
Benjamin R
Message 9 of 17
(4,698 Views)
Schema update !
Message 10 of 17
(4,697 Views)
