PXI
Task specified is invalid or does not exist
I have a C file with the following contents
#include "stdafx.h"
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <string>
#include <iostream>
#include <Windows.h>
#include <setjmp.h>
#include "NIDAQmx.h"
#include "nisyscfg.h"
#include "nisyscfg_pxi.h"
#include "nisyscfg_errors.h"
#include "pxi_driver.h"
using namespace std;
TaskHandle task = 0;
char	errBuff[2048]={'\0'};
int32       error=0;
struct fileData{
	int channel1;
	int channel2;
	int channel3;
	int channel4;
	int channel5;
	int channel6;
	int channel7;
	struct fileData *next;
} *data;
int *index;
int listSize = 0;
int tempArray[1];
int *channel1_index;
int *channel2_index;
int *channel3_index;
int *channel4_index;
int *channel5_index;
int *channel6_index;
int *channel7_index;
int *channel8_index;
int *channel9_index;
int *channel10_index;
int *channel11_index;
int *channel12_index;
int *channel13_index;
int *channel14_index;
int *channel15_index;
int *channel16_index;
int *channel17_index;
int *channel18_index;
int *channel19_index;
int *channel20_index;
int *channel21_index;
int *channel22_index;
int *channel23_index;
int *channel24_index;
int *channel25_index;
int *channel26_index;
int *channel27_index;
int *channel28_index;
int *channel29_index;
int *channel30_index;
int *channel31_index;
int *channel32_index;
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) errorCheck(); else
#define DAQmxErrChk2(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(int argc, char *argv[])
	int returnCode = 0;
	if(argc < 7){
		printf("%d arguments provided, need 6 arguments",argc);
		exit(1);
	printf("opening file %s to read\n",argv[1]);
	FILE *replayFile = openFile(argv[1]);
	if(replayFile != NULL){
		printf("finished reading file\n");
	} else {
		printf("error reading file %s...exiting\n",argv[1]);
		exit(1);
	readFile(replayFile);
	printf("creating task...\n");
	printf("Entering debug mode...press enter once connected\n");
	getchar();
	createTask();
	if(returnCode == 0){
		printf("task created\n");
	} else {
		printf("unable to create task...exiting\n");
		exit(returnCode);
	printf("Opening device %s on port %s with lines %s:%s...\n",argv[2],argv[3],argv[4],argv[5]);
	startTask();
	openDevice(argv[2],argv[3],argv[4],argv[5]);
		printf("Device opened\n");
	} else {
		printf("Device opened with warnings\n");
	printf("starting task\n");
	startTask();
		printf("Task started\n");
	} else {
		printf("Task started with warnings\n");
	printf("replaying file\n");
	filePlayBack();
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
FILE *openFile(char filePath[]){
	int returnCode = -2;
	FILE *replayFile;
	if(replayFile = fopen(filePath, "r")){
		printf("Reading file %s\n",filePath);
	return replayFile;
void openDevice(char device[],char port[],char lineHigh[],char lineLow[]){
	printf("value of task before open device is %d\n",&task);
	//DAQmxErrChk(DAQmxCreateDOChan(task,strcat(device,"/port0"),"",DAQmx_Val_ChanForAllLines));
	DAQmxErrChk(DAQmxCreateDOChan(&task,"DEV5/port0","",DAQmx_Val_ChanForAllLines));
	printf("value of task after opening device is %d\n",&task);
void readFile(FILE *replayFile){
	if(&replayFile != NULL){
		char buff[1024];
		fileData *new_node, *current = NULL;
		new_node = (fileData*)malloc(sizeof(fileData));
		new_node->next=NULL;
		data = new_node;
		current = new_node;
		while(fgets(buff,1024,replayFile) != NULL){
			char * delim = strtok(buff, ",");
			new_node->channel1 = atoi(delim);
			new_node->channel2 = atoi(delim);
			new_node->channel3 = atoi(delim);
			new_node->channel4 = atoi(delim);
			listSize++;
			current->next=new_node;
			current=new_node;
		fclose(replayFile);
	} else {
		printf("no file was opened...exiting\n");
		exit(1);
void filePlayBack(){
	printf("writing data...\n");
	int32 *numSamples;
	int32 temp = 4;
	numSamples = &temp;
	int numofChannels = 4;
	int *fileArray = listToArray();
	int i = 0;
	for(i = 0; i < listSize; i++){
		printf("writing value %d to channel\n",*(fileArray+i));
		//int value = *(channel1_index+i);
		//printf("writing value %d to channel\n",value);
		int value = *(fileArray+i);
		tempArrayValue(value);
		DAQmxErrChk(DAQmxWriteRaw(task,10000,true,-1,tempArray,numSamples,NULL));
		/*value = *(channel2_index+i);
		DAQmxWriteRaw(task,10000,true,-1,tempArray,numSamples,NULL);
		value = *(channel3_index+i);
		value = *(channel4_index+i);
		DAQmxWriteRaw(task,10000,true,-1,tempArray,numSamples,NULL);*/
		Sleep(10);
void tempArrayValue(int value){
	if(value >= 5){
		tempArray[0] = 1;
	else if(value < 5){
		tempArray[0] = 0;
int *listToArray(){
	struct fileData *temp;
	temp = data;
	int *channel1_index = (int*)calloc(listSize,sizeof(int));
	int *channel2_index = (int*)calloc(listSize,sizeof(int));
	int *channel3_index = (int*)calloc(listSize,sizeof(int));
	int *channel4_index = (int*)calloc(listSize,sizeof(int));
	int i = 0;
	for(i=0;i<listSize;i++){
		*(i+channel1_index) = temp->channel1;
		*(i+channel2_index) = temp->channel2;
		*(i+channel3_index) = temp->channel3;
		*(i+channel4_index) = temp->channel4;
		temp=temp->next;
	while(temp!=NULL){
		temp=temp->next;
		free(temp);
	return channel1_index;
void createTask(){
	DAQmxErrChk2(DAQmxCreateTask("",&task));
	printf("value of task when creating task is %d\n",&task);
	Error:
		if( DAQmxFailed(error) )
			DAQmxGetExtendedErrorInfo(errBuff,2048);
		if( task!=0 ) {
			// DAQmx Stop Code
			DAQmxStopTask(task);
			DAQmxClearTask(task);
		if( DAQmxFailed(error) ){
			printf("DAQmx Error: %s\n",errBuff);
			getchar();
			exit(1);
void startTask(){
	DAQmxErrChk2(DAQmxStartTask(task));
	Error:
		if( task!=0 ) {
			// DAQmx Stop Code
			getchar();
			exit(1);
void errorCheck(){
	printf("in error check\n");
	if( task!=0 ) {
	getchar();
	exit(1);
The program was working fine now when I run the program I get the following output
value of task when creating task is 3814276
task created
Opening device DEV5 on port 0 with lines 1:2...
DAQmx Error: Task specified is invalid or does not exist.
Status Code: -200088
What in my code could be causing this issue, or is it an issue external to the code and possibly in my hardware I am using?
(3,381 Views)
Hi jgr208,
Have you made any changes to the hardware or code after it was working properly?
Also, if you try to use these channels or create a task using this device in NI MAX are you able to do this successfully?
ShaneK
Applications Engineering
(3,328 Views)
