PXI
Stressing / Draining Lithium Battery with PXI battery simulator?
I have following tools from NI: NI PXIe-1073 and PXIe-4154. Before I was using it as battery simulator to power development boards with power supplied from PXIe-4154.
However, now I would like to drain lithium battery with a certain drain patterns to see the effect on it's battery life. I would like to simulate the load of potential device that the battery will power.
How can I drain actual battery (for example from smartphone) using my battery simulator? Is it possible?
(4,753 Views)
Accepted by armendzh
Hi armendzh,
No, unfortunately it's not. To drain a battery, you need a load, not another battery. The PXIe-4154 operates in 2 quadrants. It can only source, not sink. It can source a positive voltage and current or a negative voltage and current. A sink has negative power, so it must operate in the two other quadrants: positive voltage with negative current, or positive current with negative voltage (p=iv).
What you need for your application is a variable load and something to measure the load and battery with. If you'd like to consult with someone on what to buy, give us a call at 866-275-6964 and create a new service request.
(4,723 Views)
