PXI
Remote PXI controller without labview
I have a PXI-1065 chassis with a PXIe-8840 controller and a variety of PXI instruments.
Am I able to configure the system to see the PXI modules in the remote computer's MAX? How?
I've connected them to a switch and configured either's adapter to be static IPs on the same subnet, but can't ping each other.
Do I need to reboot into Labview RT OS for this?
Will I be able to control to the modules with a C# .NET application?  no Labview?
(1,422 Views)
PXI Instruments are programming language agnostic, as long as you use the right driver.
What OS is installed on your PXIe-8840?
Santhosh
Soliton Technologies
(1,408 Views)
