PXI
PXIe-4190
I can't find specifications of measurement range and accuracy of these parameters in www.ni.com. Please advise.
  • Y—Admittance
  • Ls—Inductance using series-equivalent circuit model
  • Cs—Capacitance using series-equivalent circuit model
  • Rs—Resistance using series-equivalent circuit model
  • Lp—Inductance using parallel-equivalent circuit model
  • Cp—Capacitance using parallel-equivalent circuit model
  • Rp—Resistance using parallel-equivalent circuit model
  • D—Dissipation factor
  • Q—Quality factor
(1,638 Views)
I believe all these are calculated measurements from the raw impedance magnitude and impedance phase values. Hence you can find the specifications for the absolute impedance magnitude and absolute impedance phase measurements is given in the specifications.
https://www.farnell.com/datasheets/3713000.pdf
Santhosh
Soliton Technologies
(1,625 Views)
