09-12-2022 09:17 AM - edited 09-12-2022 09:19 AM
Hello everyone,
I need to implement a DAQ to measure temperature, flow and pressure using a PXI. Currently the DAQ is wired so i´m looking the posibility to make it wireless.
What kind of sensor, transmitters and receivers do you recommend?
09-12-2022 10:21 AM
Since you're using a PXI, it should be analogous to "what should I do to make my computer wireless"
FYI, no you cannot make the sensors wireless, if you try to then the signal sampling location will not be the PXI instrument anymore and you don't need a PXI at all if the sensors are themselves wireless.
