PXI
PXI Backplane via pythn
Hello everybody,
I want to connect a digital signal (for example: 'PXI1Slot2/port0/line0') from a PXI-Multifuntion IO Module to the bus/ backplane of the PXI-System to trigger another module in the PXI-System.
I am using python and struggle to find an example code for this or anything close to this problem.
My idea was:
import nidaqmx
system = nidaqmx.system.System.local()
device = system.devices['PXI1Slot2']
phys_chan = nidaqmx.system.PhysicalChannel('PXI1Slot2/port0/line0')
system.connect_terms(phys_chan.name, ???)
Any suggestions?
PS: I tried to read the docs: https://nidaqmx-python.readthedocs.io/en/latest/index.html without any success.
(2,878 Views)
Hello LarsOst
Is this question still relevant? what Interpreter do you use and what controller? Also you have to configure the other module to receive the trigger.
(2,545 Views)
