PXI
PXI-4110 current limit
The PXI-4110 current settings can only be set down to 2% of their range and if Overranging is enabled then this is extended to 1% of range.
Channel 0 of the supply has a 1A range, while Channels 1 and 2 have both 1A and 20mA ranges. This would explain why the lowest current setting on Channel 0 is higher than what you see on Channels 1 and 2.
Steve B
Message 11 of 13
(1,366 Views)
Thanks for the info. I didn't see that in the documentation I had. Do You mind telling me where you found that information.
Message 12 of 13
(1,363 Views)
Never mind. I go my answer on the documentation on another post.
file: http://digital.ni.com/manuals.nsf/websearch/DDE008​44DB6F988986257826007DB0CB .
Message 13 of 13
(1,362 Views)
