‎03-02-2022 09:55 AM
My current motherboard is not compatible with MXI daisy chain architecture, that's why it is not booting up using the PCIe-8381. None of the manufacturers provide information about that spec (daisy chain on PCIe ports) which is a recommendation from NI, does anyone know a model or list with tested motherboards that can work along with the PCIe-8381 for a remote controller?
‎03-02-2022 10:52 AM
Generally, NI does not publish a list of such motherboards, same goes with Thunderbolt 3 based remote control support too.
A safer and more reliable option is to go with a PXI controller but that would be an expensive path too.
‎03-03-2022 09:35 AM
Hi Romell,
Have you tried the BIOS compatibility software (along with setting the DIP switch on the PCIe-8381)?
MXI-Express Products and MXI-Express BIOS Compatibility Software Compatibility - NI
If you have a PC where the PXIe-8381 shows up you should try the latest firmware. It helps with compatibility in some systems.
PXIe-8381 Firmware and Additional Drivers Download - NI
- Robert
