PXI
NI PXIe-7962R and NI 6585 Block Diagrams
Does anyone have any block diagram similar to https://www.ni.com/docs/en-US/bundle/pxie-5785-getting-started/page/block-diagram.html  but for NI PXIe-7962R and NI 6585? I'm trying to see the possible over-voltage failures that can affect a device connected via LVDS.
Thanks.
(782 Views)
Thank you. But I was looking for a diagram that indicates the voltage conversions in each module. I need to justify that no failure in the LVDS drivers of the NI 6585 module can cause an output voltage greater than 6 volts. One option is to verify that the LVDS drivers are only powered by the 3V3 of the PXI, which has overvoltage protection, but I see that there is also a 12V voltage that is not protected.
(743 Views)
In the following page https://www.ni.com/en/shop/electronic-test-instrumentation/flexrio/what-is-flexrio/ni-flexrio-adapte..., I found the possible values of VccoA and VccoB that power the NI 6585 module. My last question is if these configurable voltages and +3v3 rails have over-voltage protection or, in any case, what is the maximum voltage in case of failure.
Best regards.
(715 Views)
