PXI
NI PXI-6255, differential terminal configuration. How to call ch16-23?
I'm using channels 0-7 and 16-17. How to call ch16-23?
String PXI1Slot5/ai0:7, PXI1Slot5/ai16:17 doesn't work (says channel 16 doesn't exist).
String PXI1Slot5/ai0:7 works.
String PXI1Slot5/ai16:17 doesn't work (says channel 16 doesn't exist).
(3,211 Views)
Did you do any configuration of the board in MAX?  It is sounding like you somehow disabled the second connector.
(3,203 Views)
I haven't changed the configuration in MAX, so everything should be by default. But I'll check, thanks for a good hint.
(3,196 Views)
There was my mistake in a PXI slot number, so the whole topic doesn't make sense and can be removed.
(3,154 Views)
