PXI
LogosXT 5.2.1
I am trying to deploy " Network Variable Engine 1.7.0 " to PXI, an error pops up saying " Cannot continue because of the following unresolved dependencies: ...Requires Logos 5.2.2" I checked  C:\Program Files\National Instruments\RTF Images\Logos\ and found 5.2.1 folder there , can anyone tell me what is missing to deploy variable engine to PXI ?
I am running Real-Time ver. 10.0.0
Message 1 of 10
(7,091 Views)
Shimbloo,
What application are you using to deploy the Network Variable Engine? Also, do you have the Labview DSC Module installed? If yes, what version? Lastly, would you mind uploading a screenshot of the error that you are receiving?
Applications Engineer
Message 2 of 10
(7,082 Views)
Larry thanks for your reply, I am using MAX 5.0.1f  to deploy the Network Variable Engine to PXI 1082, I do not have DCS module installed but all the modules come with NI Developer Suite 2010, I have attached the snap shot of the error that I receive.
Message 3 of 10
(7,071 Views)
Accepted by htoton
Shimbloo,
I was able to determine the source of your problem. The error that you're receiving involving LogosXT 5.3 is referencing a file that comes with the 2011 version of the DSC Module. Since you have the 2010 version of the Developer Suite, this means you have the 2010 version of the DSC Module. So to get rid of this error, you simply need to upgrade the software on your computer to the 2011 version. If you have SSP support, you should have been sent the DVDs with the 2011 version of the sotware. If you have this, it should be fairly easy for you to upgrade your Labview and corresponding modules/toolkits.
Message 4 of 10
(7,069 Views)
I deleted the version numbers higher that 5.2.1 in the folder C:\Program Files (x86)\National Instruments\RT Images\Logos.  And then RT updated without error.
Ajay
Ajay MV
Message 5 of 10
(6,396 Views)
Have LogosXT 5.4.0-error.
Trying to Update RT cRIO for SCAN mode of NI 9871 RS-485 -- canno see COM PORTS???
Message 6 of 10
(6,362 Views)
Message 7 of 10
(6,361 Views)
Hi BRIANA123,
Since you replied to an old thread, which was already marked as "solved", you aren't likely to get many useful responses.  Try making a new post and include many details about the error you are seeing, such as: how to reproduce the error, the software you have installed (on computer and on the cRIO), your desired functionality, and anything else that may be useful to those trying to help.  Cheers!
Message 8 of 10
(6,331 Views)
Sorry NI -- Found moving 9871 mod from slot #1 to 8 works>>> now can see the 4 Com Ports
SOLVED!!!
Message 9 of 10
(6,225 Views)
Sorry, Found Bent Pin in Slot#1 -- Unbent NOW WORKS FINE SOLVED!!
Message 10 of 10
(6,099 Views)
