PXI
How select the channel with a PCI-1408
I'm a french student and i don't know how select my channel on my PCI-1408 card.
I developpe my software with Borland C++ 3.0
Thanks to you
(5,289 Views)
Hi Nono,
If you use the high-level imaq functions, then the default channel on your PCI-1408 will be used. You can set the default channel in Measurement and Automation Explorer(MAX) by right-clicking on a channel and selecting 'Set As Default'.
Or else, you can set the channel to acquire with imgSetBufferElement() with IMG_BUFF_CHANNEL as the itemType and the channel number as the itemValue.
(5,289 Views)
