PXI
Error ocurred in MIG hardware
HI
I am running a LabVIEW application from many time ago without any problem, but this night the function generator at our PXI has started to fail.
Checking with the MAX, the following error appears when I try to do sef-test:
The self test failed.
Status Code: -239022
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Model of Fgenerator: PXI-5412
LabVIEW version: 2015
(2,966 Views)
You should open a service request and note that your hardware needs repair (RMA).
Please follow this steps.
__________________________________________
The best way to thank, is to give KUDOS
(2,925 Views)
Did you manage to find the root cause and solution? I am having the same issue
(2,155 Views)
