PXI
Error code 63
HI,
Problem Description :
We are building a real-time application using VI server concept. The
application runs on a Windows host PC and basically calls the I/O functions
of the PXI resources working under LabVIEW RT.
We are employing the following hardware,
PXI Chassis 1006
PXI Embedded Real-Time Controller PXI-8176/RT
Analog Output PXI-6711 - 4 No's
Analog Output PDXI-AO-16/16 - 2 No's
DMM PXI-4060
Multifunction DAQ PXI-6052E
Isolated Digital I/O PXI-6527 - 2 No's
I installed the software into LabVIEW RT controller. Now when I try to open an Application reference from ATE host PC, I am getting an error 63 Which says error during Open Application reference.
I am not able to connect to RT from ATE  host PC. Can anyone help me on this???
Poornima
(3,257 Views)
Hello HCL Tech!
I am willing to bet you have your TCP/IP settings disabled on your RT Target.  To enable these in LabVIEW goto Tools>> RT Target :NNN.NNN.NNN.NNN Options....
In the Select 'VI Server Configuration' from the combo box and make sure the TCP/IP checkbox is checked.  Next goto the 'TCP/IP Access List' and make sure either the IP address of the host or a '*' is specified.  I believe this will solve your problem.  Let me know and have a great day!
Allan S.
(3,243 Views)
