11-04-2007 10:08 PM
Error -200152 occurred at DAQmx Self Calibrate.vi
at step Self Calibrate
Possible reason(s):
Data read from the EEPROM on the device is invalid.
Verify that any accessories configured with this device are connected. If the problem continues, contact National Instruments Technical Support. The device might need to be recalibrated or repaired by NI.
I have the mainframe connected to a Fluke 5700A Calibrator and The Function/Signal Gen is Manual Control ( Not sure if this is the issue ) as it says to reset the function generator
just prior to the error message. As the Function generator is not connected to the P.C. there is no possible way that the software could know if i reset it or not. As soon as i advance the screen the error appears.
Any help would be appreciated.
I'm running Cal Exec 3.2
Chris
11-30-2007 02:04 PM
12-03-2007 12:32 PM
