PXI
Connectors for customized PCB for PXIe cable assembly
I am new to the NI documentation and community. I hope I am nor asking for already solved issues or questions.
I need to design customized PCBs that exchange signals with three PXI cards: PXIe-7868, PXIe-6739 and PXI-6509. The purchase also includes this cable assemblies:
- 782914-01
- 189588-01
- 156166-02
- 157599-01
- 185095-02
They are bought in enough quantity to have all card connectors used.
What I am not sure is what would be the appropriate PCB right angle connector part-numbers to connect the cable assemblies to. I have found this information
https://forums.ni.com/t5/Digital-I-O/SCB-68-SHC68-C68-RDIO2-and-a-panel-mounted-connector/m-p/389073...
In any of the given links there is a reference to the SHC68-C68-RDIO2 mating connector for my customized PCB.
Am I right if I consider the following part numbers?
- TE Connectivity 5787169-7 -> 782914-01
- TE Connectivity 5787169-7 -> 189588-01
- 785633-01 -> 156166-02
- TE Connectivity 5787169-7 -> 157599-01
- 777778-01 -> 185095-02
I hope i made myself understood.
Thank you.
Message 1 of 1
(2,358 Views)
