PXI
Configuring PXI System: No system appears in 'Remote Systems' in MAX. How do I configure a PXI system
We have a new PXI system (PXI-8145RT Series). When connecting (through a hub) to a host PC (running Windows XP SP2, Firewall disabled, DHCP disabled), we get no systems in the Remote Systems part of MAX. If anyone has a solution, we would be most grateful.
(4,626 Views)
Hi Crow,
Have you used a straight through Ethernet cable (i.e. not a crossover)?
When you boot the PXI into Real-time, does it display its IP address on the screen?
What is the status of the ACT/LINK led's on the Ethernet connection on your controller?
Seamus
NIUK
(4,614 Views)
Hello Seamus,
Thank you for your response. I have managed to get it communicating with the host PC now (albeit in safe mode - won't communicate in 'normal' mode).
I am thinking that it is because I haven't configured my PXI system. When I identify the PXI system as a PXI-8140 RT series and the chassis as a PXI-1031, the chassis appears as unconnected with a message
'This chassis has been identified but is not described in the pxisys.ini for this system. This chassis was not present in the system during PCI enumeration'
Any ideas?
(4,600 Views)
