PXI
Change in OS in PXIe-8880 (783513-05)
We are working with PXIe-8880 (783513-05), our original configuration was with OS Windows 10 Professional, NI changed the OS to windows IOT, is it done under revision? or any other way? Where do I see the difference?
(1,390 Views)
Hi Yan_K
Windows 10 IoT Enterprise is a full version of Windows 10 with specialized features to create dedicated devices locked down to a specific set of applications and peripherals.
The difference between these OS versions is listed below.
Windows 10 Pro
  • General purpose applications such as personal computers
  • Shorter lifecycle (2-3 years, then forced upgrade)
  • Shorter support time (18-30 months)
  • Automatic updates
  • Unique product keys per device
  • Dedicated applications such as embedded systems
  • Longer lifecycle (10+ years)
  • Longer support time (10 years)
  • User controls updates
  • Has only one product key
Regards)
________
Best way to thank is giving Kudos / Marking as a solution.
(1,336 Views)
Thank you for the answer,
I understand what your saying but this wasn`t my question, we have ordered the same P/N of the PXIe-8880 (783513-05) in theory this is supposed to be exactly the same configuration (including OS), but received a different OS, I guess that NI raised the revision of the PXIe-8880 (783513-05), where I can find the old revisions and compare the difference?
(1,330 Views)
You can compare the difference the first hardware document with the second one, but there is no more information that I found.
I suggest contact NI support for more information, which will be the best way in this case.
Regards)
(1,322 Views)
