PXI
Arinc frame transmission using PXI429-3U-4
I am trying to transmit a frame of 10 Arinc words. I want to set repetition rate of each frame to 20ms whereas keeping repetition rate between each Arinc word to minimum possible value i.e., 360us (PS: I am transmitting data at high speed which is 100 kbps). Can you guide me how to achieve this?
Currently, I am able to transmit Arinc words at repetition rate of 390 us but i want it to be 360 us. Also I am unable to send Arinc frames at 20 ms repetition rate, I though of achieving this by adding 20 ms delay in loop but that does not make any difference and Arinc frames are re-transmitted as soon as previous frame is sent. I have attached my VI and output of Arnic.
M Mahboob
Message 1 of 1
(1,998 Views)
