PXI and Instrumentation Idea Exchange
About PXI and Instrumentation Idea Exchange
Have an idea for new PXI hardware or software features?
  1. Browse by label or search in the PXI and Instrumentation Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Authors
Thunderbolt 3 Interface
A Tunderbolt 3 PXIe controller card for direct connection to a PC based Thunderbolt 3 port, functioning much as the MXIe interfacing does now.
6 Comments
Wow, I completely missed that when I was looking through the PXIe controllers...
You can make up for it by buying 2.  Smiley Wink
- Robert
We are planning to use Thunderbolt 3.0 . Any issues if we are interfacing with CAN , RS485 and DAQ Modules
Since it's all "just" PCI Express data by the time it gets to the controller, the main thing to watch out for is system bandwidth, but I would assume you're fine with those types of cards. With passive cables, the PXIe-8301 should be good for around 2.0 GB/s of system bandwidth, and with active cables we've seen around 2.3 GB/s.
Michael Keane
Sounds great !  Thank You!
