PXI and Instrumentation Idea Exchange
About PXI and Instrumentation Idea Exchange
Have an idea for new PXI hardware or software features?
  1. Browse by label or search in the PXI and Instrumentation Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Authors
Simulated PXI Image Creation
Using RT Utilities or RAD works well to image and deploy when you have like systems. What about when there are many deployments to maintain, each with the same RTEXE and same driver sets, but there are many different models of PXI RT embedded controllers throughout these deployments? What if it was possible to install software to a SIMULATED PXI in MAX as well as to deploy executables and support files to? This would allow for the creation of an image for a specific model controller, without having that controller directly in hand. (BTW, I'm still on LV2013 SP1 for the next few months. I have 42 RT embedded targets that include a mix of the following models: 8196, 8104, 8102, 8115, 8100, 8135, 8820, 8840, and 9139. The same RTEXE runs on all of these. The end-user can customize I/O at run-time and therefore these deployments range quite widely in performance needs and these deployments were created over several years, hence the wide range of embedded controller vintages and performance levels. And, for my scenario, these controllers are not directly accessible through the network, as they are connected to a local network specific to that deployment location. There is a Windows host machine that has access to this local network as well as to the building network.)
