NI VeriStand Add-Ons Discussions
取消
顯示結果
搜尋替代
您的意思是:
Custom VeriStand Steps for TestStand Feedback
Hey Rajamodol,
The error you are getting is actually a Veristand error(http://zone.ni.com/reference/en-XX/help/372846B-01/veristand/vs_error_codes/). I usually get this when VeriStand is not open.  Is VeriStand fully started after the Start Veristand step? If not you might need to increase the time to wait in the properties of that step:
Kevin Fort
Principal Software Engineer
NI
0 積分
51 條訊息(共 202 條)
7,276 檢視
HI Kevin,
I have a problem with the Get Channel Value function. The config step has same page as the Set Channel Value and I do not know where the read value of the executed funktion stores.
I hope you can help me
Lucas
0 積分
52 條訊息(共 202 條)
7,276 檢視
Hi Kevin,
I have set the delay as you mentioned to 30s, 60s, 90s,... 120s... I still get "error -307652; User-defined error code." ;(
And also, the red warning in "Analysis Results" is still there, even i already initialized the Start Veristand in post #47.
I am using :
NI Teststand 2012, NI Veristand 2012
Windows 7
Microsoft .NET Framework 4 Client Profile
Microsoft .NET Framework 4 Extended
Perhaps, reinstall teststand + veristand will help?
Rajamodol
0 積分
53 條訊息(共 202 條)
7,276 檢視
Hey Lucas,
The channel value is stored in the results cluster of the step. You can access this at run time by looking at the run state of the sequence.
Rajamodol- definitely no need to reinstall.  Those are the same set of products I use for my tests.  What happens if you delete the start veristand step and just start veristand manually before running the rest of the sequnce. Can you post your sequence so I can test it out on my machine?
Kevin Fort
NI
0 積分
54 條訊息(共 202 條)
7,276 檢視
Hi Kevin,
thanks for your answer.
I have checked the variable at run-time. But the value was always zero even though the channel value was set to 1. I could also see that in the workspace.
Is it correct, that the Get & Set Channel have the same configurations page?
after we removed the Evaluate expression by the neuVal (OutputVal), the funktion works.
Lucas
0 積分
55 條訊息(共 202 條)
7,276 檢視
Hey Lucas,
You are right there is a bug there.
The error is that the new value parameter has an Evaluate() function call around the result.  You can fix it as shown above or install the updated steps installer that I just posted.
Post back if you have any issues with that.
Kevin Fort
NI
56 條訊息(共 202 條)
7,276 檢視
Hi Kevin,
Reinstall TS2012 + VS2012 doesn't help also... still have the same error.
Start Veristand step was also deleted.. Veristand was started manually, and i already waited untill ca. 2-3 mnt, then run my sequence.. same result. No chance.
Where shall i send you my sequence? Here i can only attach image and video.
Rajamodol
0 積分
57 條訊息(共 202 條)
7,276 檢視
Hey Rajamodol,
From looking at the sequence you sent me I think what is going on is that you are using the target IP address as the gateway IP.  What do you see if you provide localhost as the gatewayIP?
Kevin Fort
NI
58 條訊息(共 202 條)
7,276 檢視
Hi Kevin,
You're right.... it works now...
Rajamodol
0 積分
59 條訊息(共 202 條)
7,276 檢視
Hey Kevin,
thanks a lot for all the good information so far! I followed your instructions from the "NI VeriStand Add-on: Custom NI VeriStand Steps for NI TestStand"- sheet. I also want to configure a RT Sequence and tried to recreate your example. Now I think I´ve got a similar or the same problem as rajamodol but I coudn´t solve it. Why isn´t the "module"-button in the step settings pane displayed?
How can I get to the Module specifications?
I am using :
Windows 7
Hope you can help me!
Regards Michi
0 積分
60 條訊息(共 202 條)
7,276 檢視
