NI TestStand
window properties appear if i use double click to edit a steptype teststand
I use Labview with Teststand API. if i use ctrl + E to edit the steptype it work but if i use double click, Teststand generated me the window properties and the edit Step.
Have you some explication?
(2,315 Views)
Why don't you provide copy of your code rather than images? It is not clear at all what your problem is.
Marc Dubois
(2,299 Views)
Hello Marc,
I can't is a big project. The problem is, if i double clik in custom steptype in sequence view  to change parameters, the window properties appear with the IHM of Steptype (Error.png & Error2.png). but if i use "ctrl+E" it work.
i use the same code for "ctrl +E" & DblClick (dblclickcode.png)
(2,294 Views)
Just try to reproduce the problem in a simple sequence file that you create for that specific purpose and post it. Otherwise, we are unlikely to be able to help.
Marc Dubois
(2,291 Views)
