NI TestStand
Error when calling Veristand Logging Step in Teststand
I have been tasked with creating an automated test system which uses Teststand to sequence control of Veristand.
I am more familiar with Veristand then Teststand, but when I found that someone has previously installed the Veristand steps in Teststand, I thought great until I got the attached error!
My aim is to control Veristand Logging through Teststand.
If someone could shed some light on this issue I would really appreciate it.
Si
(2,585 Views)
Hey SRML1124
Is it the NI VeriStand Steps for TestStand you're using? If not it might be worth giving them a go?
They have their own community forum for support: VeriStand Steps for TestStand Community Forum
Also on the initialization step have you tried the "Configure Gateway" button to check the project path you're referencing is valid?
Let us know how you get on,
Rebecca
(2,559 Views)
Hi Rebecca,
Thank you for your suggestions.
They are the NI Veristand Steps for TestStand, I didn't realize they had a specific forum.
I will take a look at the forum and also try your suggestion re the initialization step.
I'll keep you posted.
Si
(2,553 Views)
