06-24-2006 07:11 AM
06-24-2006 07:54 AM
06-26-2006 01:19 PM
Hey Mr. Bean,
1) There is a subvi called Configure Event Callbacks in the block diagram. Inside of here there is a callback VI for the UIMessage handling. It is called Page Change CBack. Inside of there you'll see a subvi called Show Appropriate Tabs. This is where the tabs are being set for which one is shown. You can tweak this code to do what you expect.
2) You can just copy and paste the ReportView control onto the execution Tab. You will have to change some things in the block diagram to get it to look right. Like the code in resize controls subvi so that your execution control doesn't overshadow the new reportview control and you'll most likely have to make the new reportview control ConnectReportView. You can see how this is done by looking at the other one.
