NI TestStand
teststand 20101 SP1 f1, exception
Hello all
I have been seeing this error since recently, when I run a test sequence in TestStand 2010 SP1, f1. I call dlls made in NI LabVIEW 2010 SP1, f4.
I had been using this test sequence and dll functions since almost two months. but its just since last couple of days that I receive this error. My entire tests runs over days.
There is a dll developed in LabVIEW which, when called inside the test sequence will crash TS. Again, I have been using this dll in the test seq over the last weeks without this error!
I get errors:  "TestStand Exception" and "TestStand has to close due to an error". Off late, these errors do not come as often as I get "Memory Manager .cpp" error.
The dll function has been developed using LV 2010 SP1. That is a monitor VI whose front panel will be opened using dll call. I pass a test file name using the dll calls and then the VI will open the TDMS file and display the data till I click Stop.
this TDMS file is being written into, inside a datalogging dll which is also launched from TestStand. This dll is also developed in LabVIEW by us.
I have been using this setup since weeks and now I get this error.  Also, I get this after I had upgraded both TS and LV to the latest fixes (f1 and f4).
But the help for this error on NI website actually says we should upgrade to the latest fix inorder to avoid this error! Also there is a post recently for this error found in TestStand 2012.
Is there a version mismatch after the upgrade to respective fixes in LV and TS?
Regards
Freelance_LV
TestAutomation Consultant
(3,444 Views)
Hi again
I notice that I included an extra "1" in the title! it is TestStand 2010 SP1 f1 that I use
Regards
Freelance_LV
(3,443 Views)
I get the attached error message. the text file is one of the error logs it saved in the TEMP folder
Regards
Freelance_LV
(3,423 Views)
