NI TestStand
switching modelsupport2.dll
We are using sequences running with batchmodel with a modified modelsupport.dll i teststand user directory, because we usually need an additional entry  an additional partnumber for  each UUT and overriding pre UUT callback doesn't work well in batchmodel.
Now we have one type of UUT without that additional partnumber. Is it possible to make the sequence for that UUT using the "standart" modelsupport2.dll in installation path even if there is the modified modelsupport2.dll in teststand user ?
(4,414 Views)
Hi mkossmann,
as far as I know modelsupport.dll is part of the process model. Thus I guess you have also 2 process models. In the following link you'll find an instruction to change the process model:
How Do I Specify a Particular Process Model for a Specific Sequence File?
http://digital.ni.com/public.nsf/allkb/CEDEDEB004083D6F862572B400779E46?OpenDocument
I hope this helps.
Kind regards
Heinz
(4,379 Views)
