NI TestStand
UUT result in Post UUT Callback
Hi guys,
I have to read the UUT result  which is provioded by the below mentioned  expr.
RunState.Sequence.Main["MainSequence Callback"].Result.Status
The thing is I save the  result in Custom made TDM file and must close the file .
All this work I  do in Cleanup &  plan to do In  Post UUT   but  obviously  the
result is not available in  "  RunState.Sequence.Main["MainSequence Callback"].Result.Status"
as PostUUT callback is also part from Main Seq.
what is   the work around for this issue
(5,898 Views)
well to settle for something less
how do I get the result status for
RunState.SequenceFile.Data.Seq["MainSequence"]
(5,893 Views)
First of all, the PostUUT sequence is not part of the MainSequence, unless you make a direct call (which is NOT recommended).
As the process model calls the MainSequence, the overall result is determined once that MainSequence finishes.
Some point late, the process model calls PostUUT and passes the result as parameter. This is what you are looking for.
Btw: Don't make "SequenceFile" and "Sequence" a synonym! Even if MainSequence and PostUUT are in the same "sequence file", they are called independantly by the process model!
Norbert
Norbert
Expert: Geometry
(5,888 Views)
I think  its
RunState.Root.Locals.ResultList[0].Status
(5,887 Views)
Du hast rechts Norbert.
(5,886 Views)
