NI TestStand
step list configuration
Every time I create a custom step list configuration it doesn't show up after the sequence editor is closed and reopened. I assume the configuration is supposed to be saved out to disk but that doesn't appear to be the case. Am I doing something wrong?
kph
(4,346 Views)
In the sequence editor they are saved with the UI Configuration which is normally saved when you exit and reloaded when you restart, however if you changed the sequence editor UI configuration option (in the sequence editor options dialog) to automatically load a specific UI configuration at startup, then loading that configuration will give you whatever step list configurations existed when it was last saved. You can resave that configuration to add step list configurations to it. Also if you reset the UI configurations that will reset the step list configurations as well.
Hope this helps,
-Doug
(4,335 Views)
Thanks!!!
(4,300 Views)
Do you know where the configuration is stored so I could copy the configuration from one station to another?
Chris
(3,922 Views)
Chris,
For TestStand 4.1 and higher these files are located in: <CommonAppData>\Cfg\Seqedit
Where <CommonAppData> depends on your OS and settings typically:
Documents and Settings\All Users\Application Data\National Instruments\TestStand x.x
on Windows 2000/XP and:
ProgramData\National Instruments\TestStand x.x
on Windows Vista
For earlier versions of TestStand the files are just in: <ProgramFiles>\National Instruments\TestStand x.x\Cfg\Seqedit
Hope this helps,
-Doug
Message Edited by dug9000 on 12-19-2008 12:22 PM
(3,910 Views)
