send 1 value to 2 variable
Hi Guru,
How to send a value into 2 different variables as i attach in the attachment.
(4,010 Views)
Accepted by racdradzi
Add Locals.Result1 to your VI.
And enter in pane StepSettings->Expressions->Post Expression: Locals.Result2 = Locals.Result1.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,005 Views)
hi J_dodek,
other than use the PostEkspression method, is there any other way?
(3,997 Views)
You can write to these variables in your LabVIEW code. Pass a refernce from your sequence file to your LabVIEW code and then use the TestStand pallete in LabVIEW to write to both variables.
Shane.
(3,946 Views)
