02-06-2012 07:54 PM
Hi, All
i have a trouble about report generation.it seems the error happened at the "write UUT report"--this step is teststand report generation'DLL.
detail:
An error occurred calling 'Save' in 'Report' of 'NI TestStand 2010 SP1 API'
Access Denied.. Error writing to file 'D:\program\seq\xxx.xml'.
The file might be open in another application. If file access is intermittently denied, you should try disabling the Microsoft FindFast utility.
error code:-17205; Access Denied.
location:Step 'Write UUT Report' of sequence 'Single Pass' in 'SequentialModel.Seq'
How to fix it?
Thanks a lot.
BR
02-09-2012 10:45 AM
Hm, it looks like the file might be open in another application. If you see that file accesss is intermittently denied, you should try disabling the Microsoft FindFast utility.
