NI TestStand
reference file with relative path
I'm implementing a template sequence in my TestStand environment as described here http://forums.ni.com/ni/board/message?board.id=330&message.id=3438&query.id=340089#M3438.
My question is, when calling Engine.GetSequenceFile, how can I specify the filepath for my template file with a relative path? The file will be located within the TestStand directory structure.
Thanks for any help
(3,066 Views)
Hi Lila,
The second parameter for that function is getSeqFileFlags.  You can set that flag to be GetSeqFile_FindFile.  This will make the Engine.GetSequenceFile search the TestStand directory for the file specified in the first parameter.  Try that out and let me know if you have any questions.
(3,044 Views)
