NI TestStand
Error Code 17306 Unknown Variable or Property Name " Locals.Model"
I get the above message when i run the step f(x) SetFileGlobal operator...No code module adapter is used.
I have attached my seq file and only second and third step are erroring out..I checked the rest of the sequences they work fine. Any help is appreciated.
(3,700 Views)
You have to define the variables (Model, Operator....) in your Locals of your Sequence (MainSequence). The only variable currently defined is the default one, ResultList
Regards
Ray Farmer
Regards
Ray Farmer
(3,699 Views)
How to define them? I am just beginning ...
(3,685 Views)
Open your sequence file in the Sequence Editor.
Select the Sequence that you wish to add Locals to, and make this the active sequence i.e the one thats visible to you, Usually it displays the MainSequence  when first loaded.
Select the Locals Tab
In the right hand side of the display, there will be the variable ResultList.. This will be an empty array of Result.
Place your cursor in this position of the display and press the Right Mouse button. You will see an a popup menu of which the Top Item is Insert Local.. If you select this you will get an other set of options which are the different types of Variables that are available to you. Select a variable type, such as a Number. This will be inserted into right hand side under the ResultList array. It will be highlight ready for you to enter the name of the variable. If you double click on the variable you will get the Properties Dialog. You will beable to a new value.
The User Manual, should beable to explain on this.
I would recommend trying to get on the Basic TestStand course.
hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,675 Views)
Thanks! I will be taking one coming this week...
(3,665 Views)
