NI TestStand
"control could not be loaded" problem with TS controls
I'm getting the dreaded "control could not be loaded" display overlay on my teststand controls on my LabVIEW UI. I tried restarting my computer and tried re-running the TS version selector. Anyone have a fix instead of re-inserting my controls from scratch?
Message Edited by Michael Aivaliotis on 11-16-2007 12:25 PM
Michael Aivaliotis
VI Shots LLC
Message 1 of 19
(5,405 Views)
Michael,
I don't have a complete solution for you, but I have a few things to try:
1) Is this situation specific to one VI?  If so, then it has probably become corrupted, and you will probably have to replace the controls.
2) Do new TestStand controls work in your VI or in a blank VI?
3) Do any ActiveX controls work?  There are cases where installing multiple versions of LabVIEW can break the ActiveX container (it's a shared component).  If you can add a blank ActiveX container and browse to another ActiveX control (such as Microsoft's calendar) then everything is working OK.
4) If no TestStand controls work but other ActiveX controls work, please let me know and we'll do some more troubleshooting.
Josh W.
Certified TestStand Architect
Formerly blue
Message 2 of 19
(5,373 Views)
I ended up replacing the original controls and it fixed it. However, I just opened up the VI today and I have the same problem. This is frustrating. Not sure what causes this. To answer your questions:
I only have TS controls on this VI so I can't tell if others have this problem too. This is the main UI.
Yes, new TS controls work on a new blank VI without problem.
All activeX controls work on the same or new VI's. If I drop a container on the bad VI it works. It seems the existing controls don't work.
Michael Aivaliotis
VI Shots LLC
Message 3 of 19
(5,333 Views)
Michael,
Could you post your VI here?  Or would you be willing to e-mail it to me?
I know that we won't have all of its dependencies, but I'd like to see if we can reproduce this here, so I can assist you more directly.
Thanks!
Josh W.
Formerly blue
Message 4 of 19
(5,304 Views)
I have a support ticket open. Perhaps we can do that thru there. (7177286, 7177287). For some reason the system generated two tickets.
I can't post the code to an open forum. Let me know where you want it.
Michael Aivaliotis
VI Shots LLC
Message 5 of 19
(5,300 Views)
I will be in touch with the engineer you are working with via E-mail.  So I will take a look at your code that way.
Thanks!
Josh W.
Formerly blue
Message 6 of 19
(5,290 Views)
Was a solution ever found for this?  I am experiencing the exact same problem.  My controls are the TS ActiveX UI controls and the VI is a modified version of the LV simple OI.  the system deployed fine on one machine but all the controls on the front panel are showing this exact phrase.
TS 4.2.1
LV 2009 SP1.
please help
Message 7 of 19
(4,657 Views)
Yes, the previous poster had a service request created and submitted their VI.  After R&D had a chance to look at their code it looked like the problem had to do with more than one version of the ActiveX container on their computer. Since they had more than one version of LabVIEW installed, they had multiple versions of the ActiveX dll, and it looks like an older one was being registered. They suggested that he do a repair on one of the LabVIEW Run-Time Engines from "Add/Remove Programs"; that should fix the issue. Please let me know if this works. Thanks!
Shawn S. | NIC
Instrument Driver/IVI PSE
Message 8 of 19
(4,640 Views)
So I looked at the NI components on both systems, The one which works and the one that doesn't and there are differences in the installed componenets.  Here's the breakdown
Working System
NI LabVIEW Run-Time Engine 7.0
NI LabVIEW Run-Time Engine 7.1.1
NI LabWindows/CVI 2009 Run-Time Engine
NI Measurement & Automation Explorer 4.6.2
NI Session Manager
NI Spy 2.7.1
NI System API RT
NI System API Windows 32-bit
NI TestStand 4.2.1
NI TestStand Version Selector
NI-488.2 2.7.3
NI-VISA Runtime 4.6.2
NI-VISA Server 4.6.2
"Control could not be loaded" System
NI IVI Compliance Package 4.2
NI Measurement & Automation Explorer 4.7.0
NI PXI Platform Services 2.5.6
NI PXI Platfor Services 2.5.6 Configuration
NI Session Manager 4.2.1
NI Spy 2.7.2
NI System API RT
NI System Configuration 1.1.0
NI TestStand 4.2.1
NI Update Service
NI-488.2 2.7.3
NI-VISA 5.0.0
NI-VISA Runtime 5.0.0
NI-VISA Server 5.0.0
The big one that catches my eye is the NI System API Windows 32 bit component is missing.  how do I install just these missing components.  Also when I look at the installed software in MAX I see LabVIEW 9.0.1 is installed but I don't see this in the installed components
Message 9 of 19
(4,633 Views)
Have you tried the repair suggested above or your runtime engine?
Shawn S. | NIC
Message 10 of 19
(4,609 Views)
