NI TestStand
Disable Teststand Comments Programmatically
I know it is possible to disable the comments in Teststand by right clicking on the step, going to step list configurations, edit step list configurations and uncheck the display comments from there. However is there a way to set up Teststand so that that box is automatically unchecked?
Thank you
(3,722 Views)
Accepted by topic author Chris_H
Hi The_Judge,
When you uncheck “Display Step Comments” and apply the changes, comments are no longer displayed for the current sequences that you have open. This uncheck is saved between TestStand sessions and if you open TestStand again, comments remain not visible. This is the behavior for 2010 SP1. Are you talking about disabling step comments automatically for an initial install of TestStand?
Michael Miracle
NI Americas | AE
(3,695 Views)
No I dont believe so. TestStand has already been installed. But that should solve my problem. thank you!
(3,690 Views)
