NI TestStand
property loader
HI,
Here is what I do.
In the property step I specify the following:
StartDataMarker --- StationGlobals.TesterLocation + "_<File>_STRT"
EndDataMarker --- StationGlobals.TesterLocation + "_<File>_END"
in the file I pur the appropriate names.
xxxxx_yyyyy_STRT
xxxxx_yyyyy_END
xxxx = name as appeared in the StationGlobals
yyyy = The sequence name without the .seq extension.
Is there anything wrong with this?
The property loader ignore the file and do nothing.
Rafi
(3,491 Views)
Hi Rafi,
Can not see anything wrong, so long as the marker text in your file matchs your derived text in your variable. I think its case senitive as well.
Make sure you are not inserting any additional " (quotes).
Ray Farmer
Message Edited by Ray Farmer on 01-16-2006 11:50 AM
Ray Farmer
(3,483 Views)
Rafi,
I am including a simple sequence file containing a property loader step type using markers.
In my case I set the step to error if the start marker was not found (Edit Property Loader->Source Tab).
You could try doing the same to verify your marker is being found.
My global variable value is ¨Test¨.
Te sequence file version in 3.1.
Hope this helps.
Antonio Lie.
(3,476 Views)
Hi Raffi,
i don't know if you've solve your problem.
I find a mistake :
Your file name is "testseqfile31" and not "testseqfile"
then rename the start and stop marker and it wil work fine.
Test_testseqfile31_STRT
<Step Name> Limits.High Limits.Low
Numeric Limit Test 10 5
<Locals> Variable Value
<FileGlobals> Variable Value
<StationGlobals> Variable Value
Test_testseqfile31_END
 best wishes from France
JMCe
(3,358 Views)
