programatically set string array upper bound teststand 3.1
I am fairly new using Testand ..so I would appreciate all the help:
I created a string array using an ActiveX/COM action: PropertyObject.NewSubProperty (lookupString, valueType, asArray, typeName, options)
It creates an empty array of strings[0..empty]. How can I programatically set the upper bound of the array (for example the array of strings[0..8])
Due to my application requirements, I have to use Teststand 3.1
Thank you in advance,
Ellas1
(3,685 Views)
Accepted by Ellas1
I think in TS 3.1 you still have to use the TS API PropertyObject.SetDimensions (later TS's this has been superceded by an Array property) or you can use SetNumElements if it's a 1D array. You can of course checkout these function in the TestStand Help.
Regards
Ray Farmer
(3,679 Views)
Thank you Ray,
the SetNumElements worked great.
George
(3,655 Views)
