programatically getting properties of a subsequence steps
What would be the path to programmatically get references to steps in a sub-sequence of a sequence? - trying to accomplish that in LabVIEW.
Thanks!
(3,999 Views)
Accepted by topic author WirePipe
You can get a reference to any sequence by using RunState.SequenceFile.GetSequenceByName() and pass the name of the sequence you want to acquire a reference to.
For example if you are in the pre-expression of a SequenceCall step you could use RunState.SequenceFile.GetSequenceByName(Step.Module.SeqName) to get a reference to the sequence that is called by that step.
You then have access to arrays of steps inside of each step group (Setup, Main, Cleanup) within that sequence.
CTA, CLA, MTFBWY
(3,994 Views)
Kudo!
(3,985 Views)
