NI TestStand
precise time of wait function
Hi everyone,
I want to use a wait function in a program of TS between 2 steps with a precision of 1ms.
Wait function gives me each time diffrent time. For example I set it 2 seconds but it is not precise. the time taht I measure using Second function are 2.03, 2.06 , ...
It means I have a deviation each time in a range of 300 - 500 ms.
Is there any solution to make a presice time in TS?
Thank you so much for your help.
(1,266 Views)
You can never expect high timing precision on Windows. Windows is a general-purpose operating system. Any other program or background process will compete for the CPU resource and impact the timing precision.
Try to close all programs and run only TestStand.
https://tmesystems.net/
(1,244 Views)
Okay. Thank you @ZYOng for your reply.
(1,227 Views)
