NI TestStand
How to trigger event in LabView VI from TestStand?
I have a LabView VI with an event structure. An event is triggered when either Button 1 or Button 2 is pressed. How do I program NI TestStand to trigger the same event in the VI ?
(1,337 Views)
Use Value Signalling Property node and write value to the respective control, which will generate an event without UI Actions.
(1,291 Views)
That works! Thanks.
(1,281 Views)
