NI TestStand
passing parameters to a methode
I use Teststand 2014 and DotNet and i want to pass testlimits as parameters to a subsequence and set these testlimits in Step settings -> Limits like :
Now i want to use the limits in my DotNet code so i import the SequenceContext as an argument. But when i check the limits they are 0 in the SequenceContext (see code below). When i pass the parameters.limitLow and Parameters.limitHigh as arguments to this function, the correct values are passed. Why is passing limits via the SequenceContext not working ?
Message 1 of 1
(1,135 Views)
