08-07-2024 01:15 PM
It is not clear what setting in View, User Manager, Privilege grants the Technician, or Operator, if changed, to rerun a Failed Test?
I need a little more privilege than Execute, Terminate and Abort privilege out from a Operator profile. A rerun or run this step is needed.
08-10-2024 02:04 AM
Do you want this failed retry operation to be manual or automatic?
Usually, operators only complete fixed processes and operations, engineers will minimize the interaction between operators and the testing process as much as possible
And technicians are involved in testing, verification or debugging, which requires more interactive operations such as breakpoints, single step execution, etc
These are two different directions
If it's the first scenario, you can try implementing it with a short step, for example:
result = false
for (int loop = 0, loop < 3, loop++)
//Perform testing steps
If (//result meets expectations)
result = true
break
pass = result == true ? true : false
This achieves a simple example where the test can be retested up to 3 times after a failure, and if it passes once, it is considered successful
As for the second scenario, you can easily jump and retest on this test step by setting breakpoints and the step cursor. These basic operations will not be described again.
08-12-2024 03:05 PM - edited 08-12-2024 03:22 PM
To allow the operator to manually retest, verify User Manager - Operator group privileges allow Debug to SinglePass, RunSelectedTests and LoopSelectedTests
08-12-2024 05:32 PM
Needs to be manual of course. The Stop On Failure is checked on each test step. When a failure occurs, the Operator needs to retest the Failed (which is the current) step.
Member ee-jallen,
That looks like the correct answer. I've yet to try it.
Thanks.
