NI TestStand
ntdll.dll crash, exception 0xC0000005 After TestStand Deployment
I am trying to deploy a TestStand system, with custom test sequences, process model, some custom .dlls, and dynamic vi calls.
After finally getting the deployment to build, I can now successfully install on the deployment machine.
The deployment machine will successfully open my test sequence, and run my modified FrontEndCallbacks.seq.
I get stuck, when I try to run the actual test sequence!
When I do so, I get the error message telling me that ntdll.dll crashed. I don't know what this is, but I gather that is a Windows dll of some kind.
I am trying to figure out the cause.
Development machine: Win XP, 32-bit. TS 2010 SP1, LV 2011.
Deployment machine: Win 7, 64-bit. TS 2010 SP1, LV 2011 RTE.
The AE assisting me in this suggested that I had a .NET issue, but version 4, which was suggested I install, is installed.
Please help!
(4,801 Views)
Hi Jauron,
Would it be possible to post a screenshot of the error?
(4,787 Views)
Sure thing...
The interesting bit - this only happens if I try to run my test sequence with my modified process model. If i open a new sequence, and run it, this doesn't happen. I say this is interesting because, in either case, I am only pressing 'Test UUTs' - and this processes GUI info for the model, the test sequence isn't executed until I enter a SN and click go.
(4,780 Views)
I run into a similar issue (error attached) when I try to analyze the Source Files in a TestStand deployment. Any idea what could be happening?
(2,825 Views)
Hi farjadzaheer. Did you find a solution? I have the same Deployment utility crash report.
(2,409 Views)
