Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
NI TestStand
multiple numeric test selective Measurements
Hi
I am using a Multiple. Numeric Measurement.
with
Measurement A
Measurement B
Measurement C
I want to be selective  in which measurements I want to do. based on a Variable(bool or numeric)
i.e based on my Select switch sometimes I wont be doing  Measurement B  and sometimes I would
how  can I achieve the  same
(4,545 Views)
The easiest solution is to create 2 steps calling the same module.  One with A and C and the other with all 3.
Then just precondition them so that one runs in one instance and the other runs in the other case.
Outside of that you can dynamically change the measurements through the API either in a preceding step or in the code module.
You could also create a custom step where you can turn off and on one of the measurements.  I don't recommend this.  It seems a bit overkill.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,532 Views)
thanks for the multiple options Jigg.
(4,499 Views)
