NI TestStand
Database Option dialog shows a faulty warning dialog when using a MySQL Insert schema
After upgrading a TestStand 2013 to 2014 with a dedicated MySQL schema, I'm having the following (new) warning message when I click OK in the "Database Options"-dialog window which (I think) is not correct:
The warning is saying that I try to use on-the-fly logging (which is indeed configured) in combination with a schema with Stored Procedure or Command statements (which is not the case).
The selected MariaDB schema only contains Insert-commands. After clicking OK everything works normally so it's not a blocking thing but it's confusing. Somebody else seen this? Is it possible a bug?
Roger
(5,430 Views)
I get the exact same warning.  Just as you observed, everything works as intended.
My schema is set up for on-the-fly and every statement is INSERT only.  Since my statements are INSERT instead of SELECT, my Type selection is "Command".
I have been assuming the warning is misguided and is meant to give a place to look if an error were to occur.  Or it just missed all my INSERT statements!
(5,369 Views)
TestStand 2014 redesigned the Database Options dialog box and the conditions for this warning are likely incorrect. This is something that we will need prioritize to minimally fix in a service pack. Thank you for letting us know about this issue.
Scott Richardson
https://testeract.com
(5,359 Views)
@APSGreg
Thanks for sharing. Great to hear it's reproducible and I'm not the only one seeing this issue.
@Scott
Nice to know it's addressed . Is there (or will there be) a CAR-number associated with this issue?
Roger
(5,326 Views)
Roger -
Yes the ID of the issue is 506330.
Scott Richardson
(5,258 Views)
