06-09-2011 09:00 AM
For some reason my project no longer builds for deployment.
It terminates with the following error:
Starting Analysis Processing Workspace... Workspace Processed Finished Analysis Building... 3:56 PM LabVIEW Version: 10.0.1 (2010 SP1) (32-bit) English The build was aborted because LabVIEW is missing one or more files. The Deployment Utility is now determining which VIs Reference the missing file(s). Internal error code 7 Processing VIs... Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error: Invoke Node in Add Item Under Folders By Path - TestStand.vi->Add Top Level Items to Library - TestStand.vi->Make Top Level Library for PPL from Source Dist - TestStand.vi->Make Top Level Library for PPL Using Source Dist - TestStand.vi->PPLBuildClass.lvclass:New Build.vi->Build Distribution - TestStand.vi->Build VI Distribution 2010 (private) - TestStand.vi->Build VI Distribution 2010 - TestStand.vi->Build VI Distribution 2010 - TestStand.vi.ProxyCaller An installer was not created due to an error The build is finished 3:57 PM Aborted
Except the sequence runs fine in the editor & passes analysis.
I have checked that every step .vi is loaded & valid.
Any ideas?
06-09-2011 10:28 AM
Ah, It appears to only happen if certain options are selected in "Distributed Files" tab "Labview Options" section, including but not limted to "Output VI's to a packaged library"
but i dont understand why...
06-10-2011 08:29 AM
Hi Hoss183,
Are you running the latest TestStand 2010 patch, this addressed a number of problems with the Deployment Utility. I have included a link to the page where you can download this for your convenience.
Christian Hartshorne
NI|UK
