Check your search paths (Configure>>Search Directories) to make sure that you do not have any network paths in the list. This includes any network drives mapped to a local drive letter. If you must have a network path in the list, move it to the end of the list and make sure you do not select the Search Subdirectories option for the path unless you really need it.
