NI TestStand
logging into teststand slow
I have noticed a change in the time it takes to login to TestStand and to run sequences. Has anybody noticed a longer delay in which TestStand operates. I notice the speed of TestStand improves maybe 10-fold when it is disconnected from the network? (maybe it's just my network is slow)
(3,020 Views)
Check your search paths (Configure>>Search Directories) to make sure that you do not have any network paths in the list. This includes any network drives mapped to a local drive letter. If you must have a network path in the list, move it to the end of the list and make sure you do not select the Search Subdirectories option for the path unless you really need it.
(3,020 Views)
